1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
i need help to put an engine into my car
Old Apr 21, 2005 | 02:57 AM
dodge96's Avatar
dodge96
Default i need help to put an engine into my car
hi everyone,
i got an dodge avenger 96 420a engine and i'm trying to put mitsubishi engine
into my car and the engine is a 4G63 w/t it a 2.0l 16valve DOCH
an it the same that i got but to compare the engine. is that everything is on the oppsite side .
like my transmission is on the leftside but know its gonna be on the rightside.
if it a good idea to put that engine in to replace mind.
Old May 1, 2006 | 10:21 PM
dub01's Avatar
dub01
Default RE: i need help to put an engine into my car
the 4g63 will not fit unless you have the trans, wireing harness, and comp. if you are gonna do all that do the gst swap
( ill buy your 420a if you want to sell it, and its good)
Old May 1, 2006 | 10:25 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
ORIGINAL: dub01
It'll fit and I think you mean the GSX swap
Oh yeah, it's a good idea if you have the time and tools to do this work. The 4G63 swap is far from impossible and far from easy and well worth the time to do it IMO.
Old May 1, 2006 | 10:28 PM
dub01's Avatar
dub01
the gst is is front wheel drive turbo and the gsx is all wheel drive turbo
Old May 1, 2006 | 10:29 PM
dub01's Avatar
dub01
the 4g63 will not bolt up to the 420a trans
Old May 1, 2006 | 10:34 PM
silvercoupe97
Uber Moderator
ORIGINAL: dub01
Is that what he's saying? I thought he was going to do a motor swap []
ORIGINAL: dub01
Old May 11, 2006 | 01:03 AM
steve8678's Avatar
steve8678
has any one every converted a 2.0 avenger to a 2.5 avenger what is needed
Old Mar 5, 2007 | 07:54 PM
6g74venge's Avatar
6g74venge
just the motor trans ecu wiring motor mounts axles etc shaft all that good stuff and all 2.5s are auto so if urs is manual all the trann crap auto shifter peddles .might as well grab a man tranny off the new eclipse n make it work.. im doing a 3.5 swap n mine right now .. got all the parts oh if anyone wants a diamante 99 auto tranny n excellent condition message me
