1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Possible Interior Alteration?????
Old Feb 24, 2010 | 09:37 PM
pwilks24's Avatar
pwilks24
Default Possible Interior Alteration?????
Is it possible to alter the positioning of the a/c unit and where the radio is positioned? I was wanting to know if the radio could be raised while lowering the position of the a/c unit.
Old Feb 25, 2010 | 07:44 PM
bad venge's Avatar
bad venge
Section Moderator
Yes it's possible I've seen some move the hvac to the center console or the glovebox
You will have to extend the wires and the cabling to move the vents or you can swap to the eclipse canter console to get the double din opening and leave the hvac alone
Old Feb 25, 2010 | 08:30 PM
pwilks24's Avatar
pwilks24
Where can I get the materials for that as far as getting the wires and cable? Is it a long process and can it be a do it yourself?
Old Feb 26, 2010 | 07:24 PM
bad venge's Avatar
bad venge
Section Moderator
Most used lawn mower throttle cables to extend/ replace the cables, wires extension are pretty self explanitory
