1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
The Hesitating Avenger
Old Apr 30, 2005 | 04:45 AM
macruadhi's Avatar
macruadhi
Default The Hesitating Avenger
I just bought a 97 avenger with 112k on the odometer. When I am cruising the whole car will "jerk" as my wife says. It's kind of a shimmy as though it were misfiring, however if the vehicle is under load or coasting it runs fine. I have the auto wit hoverdrive and if it starts to shimmy and I turn off the over drive it smooths out . At idle it has a consistant misfire, if I try to push it above 4,ooo rpm it acts like it has a rev limiter, (the tach sits there bouncing off the 4k line) I had the local Autozoner check the computer codes and it just gave me something I didn't under stand. Actually I had it done twice, the first guy said it was probably just a dirty airfilter, so I changed it. The second guy said it was my gas cap either being too loose or too tight. Thanks for your help.
