1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
stumble problem thats got me stumbling!
Old Mar 28, 2010 | 04:58 AM
Jiggahnt's Avatar
Jiggahnt
You might have an oil leak that is not present when the level is low. Fill the car with the correct amount of oil and drive it a few miles then inspect the engine for leaks.
Old Mar 28, 2010 | 07:36 AM
Avengercrazy's Avatar
Avengercrazy
Jiggahnt.. I have fixed all the leaks that I have found so far, I paid like three grand for this car which seemed fine when I bought it.. Lol a few weeks later I found all the oil leaks any garage would be proud of..lol, I was also told that it could be a leak in my intake tho. So I sprayed carb cleaner around but the egine never did anything so I moved on.. Thanks for the advice, I will second check that as well..
Old Mar 28, 2010 | 01:31 PM
Avengercrazy
where did you get that trunk lid from? even tho I should get this thing running right first huh? lol
Old Mar 28, 2010 | 02:54 PM
bad venge's Avatar
bad venge
Section Moderator
It was a group buy from Extreme dimensions , Unsure if you can special order them
Old Apr 1, 2010 | 02:49 AM
Tiddy427's Avatar
Tiddy427
I had a similar problem for nearly a year, it was missing and I replaced everything under the sun to get rid of it. I finally ended up replacing my cam and crank sensors (from the dealer) with a new cam target as well, I replaced the computer about 6 months ago due to a no start and still never got rid of the miss, but once I got those sensors in there it's like it doesn't want to stop on the freeway! I love having my car back! I even got pulled over and it felt good! I have a 95 2.0L with the 5 spd. Try this, unplug your cam sensor and crank the car for about 10 seconds, I drove around with my cam sensor unplugged for almost a month it just took like 5-10 seconds to start up. That may lead you down the right path because a cam and crank sensor can cause a miss. (I'm a service writer at a shop now and I see it all day long, just wish I had the job when my car was acting up!) Hope this helps!
Old Apr 1, 2010 | 09:40 AM
Avengercrazy
Thanks i will try that. I am thinking it is just the spark plugs tho.. when i changed the valve gasket even tho i stopped the leaks in the well some oil still got on the plugs as i took them out. I sprayed them with carb cleaner before putting them back in, they are prolly fouled..
On this tapping.. i was thinking it could be the lash adjusters/lifters, but the only problem with that theory is that it does not tick at idle at all, only while revving from gear to gear, and sometimes i hear a odd tap here an there at a steady speed.. I was also told that a bad lifter can cause miss problems as well..
Thanks for all the help so far guys!
Old Apr 5, 2010 | 10:59 AM
Avenger1996's Avatar
Avenger1996
with a crank sensor more likely then not it would not start i had a 96 with the 2.0 that acted like yours is however i bought a new coil pack and the problem was solved except for the light white smoke from the tailpipe i never figured that out as i hydrolocked it and threw a rod out the side when i got the new engine put in no white smoke?? so i dont know what caused the smoke
Old Apr 6, 2010 | 08:20 AM
Avengercrazy
I know that white smoke could indicate that somehow water is mixing with compustable caponents. The tapping has slowed since I have put in some oil adaptives, but its almost as if I have a weak oil pump. The skipping is pretty much gone tho I have not figured out if it was the new plugs or the fact that I plugged off the vac hose that leaves the egr valve and travels behind the intake. I guess I will have to break down and take it to the dealer, cuz I still have a slight oil leak as well. Thanks for all the help folks!
