1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
2000 avenger stalling
Old Apr 28, 2010 | 06:11 PM
pookcat's Avatar
pookcat
Default 2000 avenger stalling
i was getting a multi misfire code so i replaced the distributor, plugs, wires cap and rotor . the check engine light went away and now it stalls when i hit the brakes anyone have any ideas?
Old Apr 28, 2010 | 08:54 PM
bad venge's Avatar
bad venge
Section Moderator
Any other codes ???
stalling can be EGR troubles ,IAC troubles,leaking intake gasket (since you just changed plugs)
Old May 13, 2010 | 09:13 PM
pookcat's Avatar
pookcat
i pulled the egr valve then made a block off plate and it fixed the problem. now i just need to replace the egr valve which i am not in a hurry to do since it is expensive like everything else on this peice of ---- car.
