1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Gas Level Sensor Problem
Old May 8, 2010 | 04:39 PM
KillboyPowerhead's Avatar
KillboyPowerhead
Default Gas Level Sensor Problem
When I fill up my car with gas I have to squeeze the handle of the nozzle very lightly or else the gas stops pumping, as if the tank were full. Does anyone know what could be causing the problem or what is not working properly?
Thanks in advance.
Old May 8, 2010 | 07:22 PM
bad venge's Avatar
bad venge
Section Moderator
your tank vent line is likely plugged
Old May 19, 2010 | 09:43 PM
KillboyPowerhead
How would I go about fixing the vent (or at least, where is the vent located)? I don't know a whole lot about cars and I can't find any info on this in the service manuals/internet.
Old May 19, 2010 | 09:48 PM
bad venge's Avatar
bad venge
Section Moderator
If you look at th rear of the fuel filler neck theres a large main hose and a smaller hose that runs along it check the small hose
