1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Sound when door is opened and key is not in the ignition?
Old Jul 4, 2010 | 06:30 AM
jonthee's Avatar
jonthee
Default Sound when door is opened and key is not in the ignition?
Hi!
I always have this sound when I open the drivers door, shouldnt the sound only be there when I have forgotten the key in the ignition? It is really annoying, I cant work with the car, it drives me crazy =/
Thanks in advance.
Old Jul 4, 2010 | 07:23 PM
bad venge's Avatar
bad venge
Section Moderator
It's likely a bad door switch... Do the dome lights work ?
Check the screw holding the door for a good ground
Old Jul 5, 2010 | 02:05 AM
jonthee's Avatar
jonthee
Thank you!
Going to check that instantly!
