1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Downpipe/california/federal/exhaust/etc
Old Nov 5, 2010 | 10:10 PM
pghsebring's Avatar
pghsebring
Default Downpipe/california/federal/exhaust/etc
Someone tell me the difference between federal and california exhausts on a 98 2.5L.
One has a one piece rear exhaust manifold/converter, one has a two piece rear manifold/converter.
One has a down pipe that has 3 o2 sensors in it, and one has a downpipe with only 2 o2 sensors in it (the third one is on the cat in the 2 part manifold/cat). Does only the one with 3 o2 sensors come with a cat in the downpipe/frontpipe too?
Which is which?
Right now i'm thinking the california one is the one with the two piece rear manifold/cat...correct?
Old Nov 6, 2010 | 10:16 AM
bad venge's Avatar
bad venge
Section Moderator
I'm thinking it's the other way around. Mine has the 2 piece. I'm thinking the one piece would be cali to prevent removal or test pipes
Old Nov 6, 2010 | 12:45 PM
pghsebring's Avatar
pghsebring
Look at the emissions label under you hood and see if it says it meets federal or california emissions. Mine says federal and has the one piece.
Old Nov 6, 2010 | 01:34 PM
bad venge's Avatar
bad venge
Section Moderator
I'll my stickers were removed years ago, I ordered the car for Ohio and doubt it would come otherwise
Old Nov 7, 2010 | 01:16 PM
pghsebring's Avatar
pghsebring
This is why no one will ever know the answer to this question...its unreal.
Old Nov 7, 2010 | 04:12 PM
bad venge's Avatar
bad venge
Section Moderator
Dealer should be able to answer by looking up parts Cali versus non cali
