1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
R/R CV axles 97 Avenger
Old Dec 3, 2010 | 08:51 PM
Partsman41953's Avatar
Partsman41953
Default R/R CV axles 97 Avenger
I now find out that the CV axles on my 1997 Avenger ES 2.5 are bad. How difficult are they to replace. The dealer and some of the repair shops where I live want almost $700 to replace them. I do not think it should be that difficult but I may be wrong. How would one go about replacing them?
Thanks,
Glenn
Old Dec 3, 2010 | 09:30 PM
sapporo's Avatar
sapporo
get a service manual and follow the directions. if you can make a box cake, you can replace axles... it's all a matter of following directions and understanding terminology. you'll probably need to rent, beg, borrow, steal or buy some tools to complete the task.
even if you have to spend a couple hundred on tools and a couple hundred on axles, you've saved $300 plus then you'll have more tools which can be used to save more money in the future and even make money fixing stuff for people that are in the same situation you're in.
Old Dec 4, 2010 | 08:10 PM
bad venge's Avatar
bad venge
Section Moderator
WOW talk about overcharging ... I called two local shops and was quoted $150 passenger side and $250 drivers
It's a fairly straight forward change out unledd the axles froze in the hub
