"Rubber against metal"-sound when turning!
Hi!
I've recently got this annoying sound when I turn the steering-wheel, no matter if I drive the car or stand still.
The sound is noticeable when I turn both left and right.
It sounds like rubber against metal
What can it be?
Thanks in advance!
Best regards
What can it be?
Thanks in advance!
Best regards
Hi again!
Thanks!
What would you have bought? The ball joints on ebay costs only $42 incl. shipping international.
I forgot to mention, 2 hours before the sound appeared, I ran over some big holes in the ground (working area), had no warning sounds so I didnt see them, but the car really went "off-road" there.
I also forgot to mention that the power-steering fluid was low, but I filled it up and it doesnt seem to be leaking (yet), so maybe thats not it because the sound is the same when I push the car manually upp and down while it is still and the engine turned off, so maybe it is something with the ball joints, control arm?
Will balljoints from a Mitsubishi galant fit? From -92? My local dealer says galant ball joint from -92 fits galant 93-96 + some other mitsubishi's and Volvo s40?
Best regards
Thanks!
Best regards
I will do that.
Maybe they are the same as Mitsubishi Galant -96? Or Dodge/Chrysler Stratus/Cirrus?
But the stange thing is, would a bad CV joint be making noise when you bump the car up and down by hand (right side)? Can that be the ball joint, upper or lower?
I will order a ball joint (upper) also and if the CV joint is bad I will fix that too, but how will I notice a defective CV joint?
Thanks in advance!
Best regards
Thanks in advance!
Best regards
Pretty obvious I cannot diagnose over the internet.
YOU will have to do inspection / look over the suspension and check for play/damage/loose/damaged CV boots check for grease everywhere
Parts for the 95/99 eclipse would be the more likely swap parts I can't say on the galant
