1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
front end squeaking bad
Old Feb 14, 2011 | 01:14 AM
jahorman's Avatar
jahorman
Default front end squeaking bad
Hello everyone,, i want to know if there is a quick fix to a squeak... Im not sure what it is but it is on the front drivers side,,, I think it is the shock because when it is parked if i push down on the front end it squeaks loud going down and coming back up... This sound is just so annoying and embarrassing when driving around town... Is there anything i can spray on or something i can do cheep to fix it... thanks
Old Feb 14, 2011 | 06:04 PM
bad venge's Avatar
bad venge
Section Moderator
You have to identify the noise ...
It can be the strut mount on the top.
A arm bushings
Either of the control arms
Sway bar bushings
Bad Strut
Bad bottom mount
Sometimes a spray of silicone will quiet it till it gets wet Other times it needs the bushings replaced or arms or strut
