1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Hard to replace lower control arms?
Old Apr 6, 2011 | 04:40 AM
jonthee's Avatar
jonthee
Default Hard to replace lower control arms?
Hi!
I have two bad control arms on my Avenger, boguht some new ones and will buy a "ball joint" fork.
Is it hard to replace them? It is the lower fronter control arms, the ones that are "straight".
It looks like there are two bolts only?
Can I just raise the car and replace them on each side? Any specific tourqe on the bolts?
The only special tool is a ball joint fork?
Thanks in advance.
Best regard
Old Apr 6, 2011 | 04:37 PM
bad venge's Avatar
bad venge
Section Moderator
Yes pretty much correct yes there is a torque spec. I'm traveling and don't have my manual with me
Old Apr 9, 2011 | 02:25 PM
jonthee's Avatar
jonthee
Hi!
Thanks for answering,
Soon I will have the both control arms, they are on their way fron Chicago, USA to Sweden
So all I need is a ball joint fork and a socket wrench? Which size are the bolts?
Does it matter how hard I "tourqe them"? Or do I need the exact tourqe-number?
PS, I am talking about the lower front control arms, which are "straight" and not "bent".
Thanks in advance.
Best regard
Old Apr 15, 2011 | 01:39 PM
jonthee's Avatar
jonthee
Hi again!
Did you find out what the specific tourqe was?
Must I think of something special?
Can I just raise the car with a jackstand and remove the wheel, then loosen the bolts holding the control arm? Or must I remove enything else?
Thanks in advance.
Best regards!
Old Apr 15, 2011 | 01:48 PM
bad venge's Avatar
bad venge
Section Moderator
As mentioned I am traveling out of country I do not have my manual...I'd suggest getting one of your own or going to the library ...
Old Apr 15, 2011 | 05:44 PM
jonthee's Avatar
jonthee
Oh sorry, thought you'd be back by now =)
I have a manual for a Chrysler Cirrus and will follow the tourqe spec. for that car since I must replace the control arm tomorrow.
But its a straight forward job right? Just jack up the car and losen the bolts and bend the tie rod of with the tie rod-fork? Or must I loosen something else to "fit" the tools?
I will get back tomorrow about how it went
Best regards
Old Apr 26, 2011 | 03:37 AM
jonthee's Avatar
jonthee
Sorry for late response:
It was pretty easy to replace the arms, took me about 2 hours and I only had to loosen the wheels and the 2 bolts holding the arm and ofcourse the tie rod/ball joint.
