1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
CPS Testing procedure
Old May 20, 2011 | 10:38 PM
bad venge's Avatar
bad venge
Section Moderator
Default CPS Testing procedure
If you can move the battery out of the tray a bit but leave it hooked up...unbolt the Crank sensor on the top of the trans at about 1 oclock. Leave it plugged in and use a sharp electical probe to probe the weather pack connector being careful to slide it in next to the wire not into the insulation.
using a digital volt ohm meter like sears sells for twenty bucks and with the key on but engine not running...no prob right!...you should have nine volts on one wire, about 5 volts on another and next to nothing on the ground wire. hold something metallic up to the end of the sensor usually inside the trans...it should pull the 5 volts to zero. buy a new sensor if it is 9 ,0 and 0 and one of them pops up to 5 when you unplug it in the open air as described above.
