1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Can't Turn Key
Old Jun 1, 2011 | 01:05 PM
KillboyPowerhead's Avatar
KillboyPowerhead
Default Can't Turn Key
Earlier I decided to replace the guide pins on my front brakes, so I turned the steering wheel to get at the brakes more easily. While turning the steering wheel I heard a click (near the end of the wheel's turning range). When I finished with the passenger side I attempted to start the car so that I could turn the wheel to get at the driver side brakes, but I could not turn the key at all. I also could not turn the steering wheel or take the car out of park.
Any ideas? I read about putting the key into the ignition and hitting it with a hammer (apparently this worked for a bunch of people) but it did not work for me.
'97 2.5L
Nevermind, got it working. There was still a bit of play in the steering wheel, so I guess you can turn the key while turning the wheel all the way.
Old Jun 1, 2011 | 08:37 PM
bad venge's Avatar
bad venge
Section Moderator
Have you tried wiggling the wheel back and forth while turning the key ?
Also the shifter try moving it
likely the crack you heard might have been the pin breaking
