1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
97dodge avenger 2.5l
Old Aug 14, 2011 | 09:07 AM
sdunagan78's Avatar
sdunagan78
Default 97dodge avenger 2.5l
replaced distributer assemble and crank position sensor still don't have fire
Old Aug 14, 2011 | 10:30 AM
bad venge's Avatar
bad venge
Section Moderator
do you hear the fuel pump prime ? does it have voltage ?
Old Aug 14, 2011 | 07:06 PM
reed2222's Avatar
reed2222
Try/test your firewall relays... should be 3 of them. Check all your fuses.
Old Aug 28, 2011 | 09:25 AM
sdunagan78's Avatar
sdunagan78
i replaced all three relays and the fuel pump still doesnt come on but i pulled fuel pump it is good and i still dont have any fire and no signal to injecters
Old Aug 29, 2011 | 09:04 PM
bad venge's Avatar
bad venge
Section Moderator
Doyou have voltage to the fuel pump ? if not the relay is defective/wires are broken or it's not being turned on by the key
