1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Rough Idle - No Power - Whistling
Old Dec 10, 2011 | 07:08 PM
  #21
bad venge's Avatar
bad venge
Section Moderator
The TPS is highly unlikely I've only seen one bad TPS sensor out of thousands of cars.
It's not used at Idle as well
Old Dec 11, 2011 | 10:18 AM
  #22
szpilafam's Avatar
szpilafam
would the tps cause the rpms do come down slowly?
Old Dec 11, 2011 | 02:39 PM
  #23
bad venge's Avatar
bad venge
Section Moderator
At Idle> NO the IAC runs this
When Driving the Throttle control spring or a bad Cable
Old Dec 11, 2011 | 10:40 PM
  #24
DarkVenge's Avatar
DarkVenge
I should have said that in my first post. The TPS was replaced 2000 miles ago because the other one was broken.
Also, the IAC wasn't replaced. It was cleaned.
I replaced my EGR valve tonight with a new BWD one. I'm going to go test it out and let you guys know what I find. I started the car and the rpms were still going down slow, so maybe my IAC is bad, too, lol. Thanks for the help so far.
