1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Idle problems
Old Sep 1, 2011 | 04:30 PM
red-venge's Avatar
red-venge
Default Idle problems
Hey all
I recently bought a 1998 avenger es and i've already had to repair it once
I was having symptoms of EGR valve and IAC problems. I took it to a mechanic and they ran a diagnostics test on it, it ended up being my #1 fuel injector, it stopped my knock and shake in the engine and it ran alot smoother.
I do have a check engine light the code is P0443 which is the evap purge valve control
the car does burn a bit of oil out of the exhaust during start-up and if i've been sitting at a stop light for awhile but not while driving down the road
i was sitting at a drive thru earlier and the car stalled out
i was wondering if maybe the error code or the burning oil could cause the car to stall out like that?
