Component Speaker System Question
Need some help on installing this component speaker system :
http://www.ebay.com/itm/390331024635...84.m1423.l2649
to an existing Infinity amp and stock stereo head unit. My plans are to reuse the Infinity amp and remove the stock speakers and tweeters. Is this an easy replacement? Not sure what a cross over is? Is this something I will need to run additional wiring? Any help would be greatly appreiciated.
Here is the spec on the system:
- Brand New Kicker 6.5" + 6x9" Car Speakers Package
- 6.5" Kicker Speakers:
- BRAND NEW KICKER DS652 6.5" 240 WATT 2 Way Car Component Speakers
- 120 Watt MAX (240 Watt Pair)
- 60 Watt RMS (120 Watt Pair)
- Heavy-duty motor structure for improved performance
- Extended Voice Coil (EVC™) woofer technology for ultra-clean bass
- Ribbed UV-treated surround for precise linear excursion and optimum sound
- Titanium-dome tweeters with oversized voice coils for outstanding definition
- Three tweeter mounting options: flush, angled or surface
- External crossover/protection network features three-position adjustable tweeter levels for dialing in high frequencies
- 3/4 Titanium Dome Tweeter
- Sensitivity: 90dB
- Frequency Response: 35-21k
- Part Number: 11DS652
- Product Condition: BRAND NEW
- 2 Year VMinnovations Warranty
- 6x9" Kicker Speakers:
- Brand New Kicker 6x9" 280 Watt 3 Way Car Speakers
- 140 Watt MAX (280 Watt Pair)
- 70 Watt RMS (140 Watt Pair)
- Drop-in factory upgrade for easy fitment into any vehicle
- Extended Voice Coil (EVC™) technology for ultra-clean bass
- Balanced-dome tweeters for outstanding definition
- Sensitivity: 92dB
- Frequency Response: 30-21k
- Part Number: 11DS693
- 2 Year VMInnovations Warranty
The Infinity Amp has a built in Crossover to send the frequencies to the correct speaker
You can mount the tweeters in the dash . I'd cut a Plexiglass plate and then centerdrill the correct diameter for the speaker, then install the stock grill over it, I'd install a bass blocker or you could connect the crossover to the tweeter line and then the tweeter.
Mount the drivers in the door
Thanks BV.... Do you think this is an OK component speaker system or do you think I need to go another direction? I can tell you that the door speakers and dash tweeters are toast but the rear deck 6x9's still sound pretty good.
"I'd install a bass blocker or you could connect the crossover to the tweeter line and then the tweeter". Ive never heard of a "bass blocker". Is that something I need?
Crossover ... Tweeter line. Could you explain that to me please?
"Mount the drivers in the door" Are you refering to the 6.5 speakers or the crossovers? Sorry for my ignorance.
http://www.crutchfield.com/shopsearc..._blockers.html
the stock tweeters /amp cut off lower then those kicker tweets , you might actually be missing some frequncys cut by the amp and blocked by the bass blocker
The crossover has input from the head unit and output to the tweeters and the drivers You could connect the tweeter line to the input and the tweeter output to the tweeters
These will act as crossovers
Yes drivers= door speakers
