1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Question about dome lights and key Fob
Old Sep 13, 2011 | 08:46 PM
reed2222's Avatar
reed2222
Default Question about dome lights and key Fob
Wondering if someone could tell me what the dash dimmer control **** fuctions are. I get that it dims the instrument cluster (it works) but what is its fuction all the way counter clockwise? One more question... i noticed that i get no notification (tone) when the head light are left "on", when the key is removed... is this a relay problem some where?
Ok.. one more... on the key fob there is a "panic" button, this has no function any reason why?
2000 Avenger ES
Old Sep 13, 2011 | 10:10 PM
bad venge's Avatar
bad venge
Section Moderator
the dimmer has no function on most cars , the click works ro turn on the lights on non sunroof cars
the tone is a green relay under the dash might be missing most remove it
the panic is supposed to honk horn
Old Sep 14, 2011 | 12:01 AM
reed2222's Avatar
reed2222
Old Sep 14, 2011 | 12:11 AM
reed2222's Avatar
reed2222
http://www.facebook.com/media/set/?s...105f087&type=1
BV is this the Relay block under the dash your referring to? I did not notice a green relay. It appears one is missing. What do you think? Do you by chance know the relay number?
