1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
performance tuner
Old Jul 25, 2005 | 06:25 PM
speedfr3ak's Avatar
speedfr3ak
Default performance tuner
does anyone know if there is a performance tuner for a 95 avenger es... if u dont know what it is its a little computer that you plug into your e.c.u. and allows you to upgrade ur h.p. torque and air/fuel ratio.
thanx
Old Aug 19, 2005 | 03:32 PM
Steve@ExileRacing's Avatar
Steve@ExileRacing
Default RE: performance tuner
There is nothing available in that area, best thing is to use something like a SAFC or similar fuel tuning device.
Old May 11, 2006 | 07:15 AM
stock92csm's Avatar
stock92csm
can we use a second gen eclipse, datalogger?
Old May 11, 2006 | 09:03 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I'm pretty sure the parameters are different, since the 2g's are 4 cylinders.
*edit*
Just remembered that you have a 420a, you can see what the 420a guys are using to datalog and use that.
Old May 11, 2006 | 11:02 AM
stock92csm's Avatar
stock92csm
that's what i have tho i have the 2.0 dohc, and i'm waiting on a friend to send me blue prints of the neon r/t head and avenger 2.0 head, he said the main difference he has seen so far is exhaust cam and port sizing :-) so this may give some leeway for the 2.0 avenger owners, it'll be nice if we can toss that head on out cars or even just the exhaust cam, you'd have to change the base timing tho and get adjustable cam gears do some fine tuning but it should be a nice lil project, i'm just gonna buy the cam tho and have the head set to the r/t specs. I just got a call from him only difference is cam and port/bore sizing . I hope he's correct. according to his desktop dyno simulation, switch the cams and have the head work done to follow, w/ headers and hi-flo cat it'd give leeway to around 150-154 hp maybe higher with timing edit
