1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1996 Avenger won't shift out of 1st gear
Old Dec 1, 2011 | 11:25 PM
jsocha389's Avatar
jsocha389
Default 1996 Avenger won't shift out of 1st gear
1996 Avenger V6 Auto / Tranny will shift out of 1st when very cold to 2nd only - 1 time - after that it stays in 1st.
Sensor or TCM?
Old Dec 2, 2011 | 07:42 PM
bad venge's Avatar
bad venge
Section Moderator
Does the speedo Read ?
Sounds like you are in limp mode
Could be input or output speed sensor , if the speedo reads then it could be the input sensor , if the tranny does not read its the output sensor
You can get the trannt scanned for codes
Old Dec 4, 2011 | 02:46 PM
jsocha389's Avatar
jsocha389
Speedo works fine - no check engine light on either?
Old Dec 4, 2011 | 05:11 PM
bad venge's Avatar
bad venge
Section Moderator
the tranny will not trip a check engine light but a high order scanner can read the tranny codes
Old Mar 7, 2012 | 10:45 PM
Jimmie Mitchell's Avatar
Jimmie Mitchell
input or output sensor...or (3or4)relays on firewall dont let them tell ya its the tranny...
