1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Data Link Connector dead?
Old Jan 16, 2012 | 11:29 AM
Wildcat3's Avatar
Wildcat3
Default Data Link Connector dead?
I recently bought a '97 Avenger ES for my son as his first car. It has a few issues so I'll try to only post issues that I haven't been able to find an answer on this forum. It's a pet peeve of mine when newbies post questions without searching for the answer first, when it's been addressed previously 9,000 times.
The engine was recently rebuilt and the CEL light was on when I purchased it. I have an OBD II reader, plugged it into the Data Link....nothing.
Just to make sure my reader wasn't bad, I plugged it into my other vehicle and verified it is working.
I have the fuse diagram from the Haynes manual but didn't see anything for the Data Link Connector. I did the 'key dance' method and got the following:
1 - 2 - 3 - 1 - 5 - 5, which I assume is codes 12 and 31. And 12 indicated no power to the PCM I believe or battery completely disconnected within the last 50 starts (I'm hoping that's all it is.) But I'd still like to have a functioning Data Link Connector since I'm planning to reprogram a wireless key fob soon.
Any suggestions? Thanks!
Old Jan 16, 2012 | 12:32 PM
bad venge's Avatar
bad venge
Section Moderator
Check the fuses it's piggybacked on another fuse , I have it written down on my shop manual I'll see tonight after work
Old Jan 16, 2012 | 04:53 PM
Wildcat3's Avatar
Wildcat3
Thanks, I appreciate that!
Old Jan 17, 2012 | 09:26 PM
Wildcat3's Avatar
Wildcat3
Did you run across it by chance?
Old Jan 18, 2012 | 05:00 PM
bad venge's Avatar
bad venge
Section Moderator
Sorry I lent out the electrical manual to another guy (I wrote it in there) Should be in the electrical schematics
Old Mar 17, 2012 | 11:07 PM
fixitfirstime's Avatar
fixitfirstime
This car has two diag connectors. The obd II one for communications and the Mitsubishi one next to it that has the power in it. At least when you hook up the factory scan tool that is the way it works. There is a "y" cable that hooks to both and carries power and communication.
Old Jul 21, 2014 | 01:47 AM
xILLICITx's Avatar
xILLICITx
I am having the same prob with my 98 es but I only see the datalink connector I don't see the other one.
