1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Error code: p1294
Old Feb 8, 2012 | 11:07 PM
Ghoulface's Avatar
Ghoulface
Default Error code: p1294
I was getting a CEL on my 2000 avenger a few months ago i finally hooked up my phone to the obdii and it says im getting error code p1294
where can i find a explanation for this error code
i googled it and asked a few mechanics what this is, but they both gave me the run around.
Old Feb 9, 2012 | 04:20 PM
bad venge's Avatar
bad venge
Section Moderator
P1294 is Target idle not reached. basically it could be a vacuum leak causing a high idle, or a bad Idle Air control solenoid.
Old Feb 10, 2012 | 04:24 PM
Ghoulface's Avatar
Ghoulface
could either of those explain why my car sometimes just shuts off?
to explain the situation when this started happening i would be going down the road at 25-75mph and the rpms would go down to 0 then when i pull over it just suddenly starts back up by itself... please if you have any idea what this could be please help i have taken it to 4 mechanics and all of them replaced some parts they said could cause this happening...
btw thanks badvenge you have been very helpfull
Old Feb 10, 2012 | 04:42 PM
bad venge's Avatar
bad venge
Section Moderator
Your symptom sounds more like a bad CKPS or CPS crank position sensor /cam position sensor
