1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
distributor
Old Feb 21, 2012 | 05:18 PM
szpilafam's Avatar
szpilafam
Default distributor
I'm wondering if something could be causing my distributors 2.5l dodge avenger to go bad????? I have replaced it 4 times now and it just went out again.
Old Feb 21, 2012 | 07:13 PM
bad venge's Avatar
bad venge
Section Moderator
Have you checked the PLUGS for oil ?
I'm guessing that they could be grounding out and killing the unit
Old Feb 22, 2012 | 10:24 AM
szpilafam's Avatar
szpilafam
that would be it, back left one full of oil. gave me a code first primary coil voltage, then dead. checked continuity and its the coil. now i have 4 distributors layin around. nothin I can do with them to repair?
Old Feb 22, 2012 | 04:24 PM
bad venge's Avatar
bad venge
Section Moderator
I've never seen parts for them ....
you can get rebuilt ones and use it as a core ,
Or you could use an external MSD type unit
