1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Automatic Transmission won't switch into reverse
Old Oct 1, 2012 | 05:52 PM
whit-it's Avatar
whit-it
Default Automatic Transmission won't switch into reverse
I recently overhauled my 97 avenger after 2 years of sitting, and my transmission was having this problem a few months before it went out of commision. Transmission will not go into reverse. Is there any easy solution to fix this. I was thinking about replacing the Transmission Solenoid or the Powertrain ECU. Hoping that one of these may solve my problem.
Is there anyone that has ever had this type of problem. Please Help.
Old Oct 2, 2012 | 06:02 AM
bad venge's Avatar
bad venge
Section Moderator
When you shift into reverse do you hear a "ratcheting" type clicking sound from under the hood ?
Old Oct 4, 2012 | 05:27 AM
whit-it's Avatar
whit-it
No. I did some research it came about the solenoid. Well. I just replaced it still the same
Old Oct 4, 2012 | 01:54 PM
whit-it's Avatar
whit-it
OK, I have another problem, I just replaced the Transmission Solenoid and it still soing the same thing. any other suggestions before I decide to, either, take it to the shop or replace it with a used one from the autowreckers.
Old Oct 8, 2012 | 12:22 PM
bad venge's Avatar
bad venge
Section Moderator
I'd check voltages to the solenoid pack if you are not getting the ratchety sound that tells me the electronics are not giving the solenoids power
Old Oct 31, 2012 | 07:05 AM
whit-it's Avatar
whit-it
Yeah. Im getting the racheting sound.
