95 avenger starting problems
Hi I am a nube at this so please help. I have a 95 avenger ES V6. It has been cutting out on me while I drive but continues to run after a second or two. It also doesn't always start. About 85% of the time it doesn't. When I stick the key in the ignition there is a clicking sound in the left side near the vent by the driver window and in the back of the car somewhere. Then it will loose all power. I really need this car to work for me. Please someone help. This car also has an automatic start that was already installed when I bought it. I don't know if that has anything to do with it.
On a side note, I have read somethings that say to change a bunch of sensors and egr valve and relays. Which do I do??? |
If it won't crank the sensors are not the trouble you have battery/cable/connection issues , it could be the remote start as I'm not aware of any relays clicking where you describe (they might have mounted ones there )
