1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
99 avenger 2.5 no spark
Old Mar 28, 2013 | 10:20 PM
gamundson3's Avatar
gamundson3
Default 99 avenger 2.5 no spark
Have replaced cap, rotor, plugs, wires, egr, crank sensor, map sensor, 30 amp asd, 30 amp fuel.... getting fuel but no spark. Ran great for about fifteen miles. had oil changed and top end motor cleaned. ran rough afterwards. CODE #5 mis-fire. repluged #5 back in from idiot that cleaned engine,now no spark from distributor!!! IGNITION COIL????? Please help!!!!!
Old Mar 29, 2013 | 12:21 PM
bad venge's Avatar
bad venge
Section Moderator
Since you replaced the laundry list of parts did you do any troubleshooting or just start swapping parts ?
Did you check for 12 volts feeding the distro?
the coil is built in the distro
