1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Best Spark Plugs 1997 2.5
Old Apr 26, 2013 | 03:12 AM
newfuel2008's Avatar
newfuel2008
Default Best Spark Plugs 1997 2.5
Hello Everyone, I am preparing to replace the spark plugs on my 1997 Avenger ES 2.5 V/6. I noted that 3 brands of plugs are mentioned in the owners manual as acceptable choices.
My question is: Which plugs are the best choice for this engine? Longest lasting, as well as good mpg and performance?
I bought this car new. It has 91,000 miles on the original plugs. I am getting misfire codes. Multiple, as well as misfire on cylinder number 2 and 4 pending code. Also, the last O2 sensor downstream is showing bad according to the scan tool.
Thanks for your feedback on Best Spark Plugs for this engine.
God Bless,
George
Old Apr 26, 2013 | 09:22 AM
bad venge's Avatar
bad venge
Section Moderator
I've been running the Denso Iridium plugs , While you are there Replace the wires
Also inspect the plugs for oil , if you find oil replace the valve cover gasket and Plug well seals. Also replace the cap and rotor
Old Apr 28, 2013 | 12:25 AM
newfuel2008
Thanks Bad Venge, I will do that and report the results.
