1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Abs motor relay number
Old Jan 13, 2014 | 01:55 AM
elbiociq's Avatar
elbiociq
Smile Abs motor relay number
Does anybody know what is the relay number of the abs motor relay mounted on the box by the abs hydraulic unit on the 95 Dodge Avenger 2.5L V6 ES? I went to the dealer for a diagnostic and they sold me the wrong relay. The problem I have is that when I have to stop when it is snowing the car starts to skid all the way to the left. I believe it is because the right rear speed sensor is broken and when the computer senses that the car is sliding the abs starts working for all the wheels but the right rear one since it is broken and keeps pulling to the left. If anyone happens to know what the number for that relay is and if it possible the number of the other relay right next to it (the solenoid relay) too, I would really appreciate it. You may be thinking why you don't lift the car and open the abs motor box and take a look. If someone has a relay like that outside the car and can read the number. Remember is a 95 Avenger, I don't know if there is any different from other cars built in different years but I know that for some parts is only 95-96, for instance the abs hydraulic unit. Thank you.
Old Jan 13, 2014 | 05:30 AM
simmonsfr's Avatar
simmonsfr
There may be two inside the hydraulic unit.MB858789, MB407392, or MB618039 are possible relay numbers. Ebay has three different relays listed. See link below.
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Old Jan 15, 2014 | 07:41 PM
elbiociq's Avatar
elbiociq
Smile Original japanese abs relays
Thank you for the information. I found two replacement relays I had out from another hydraulic unit and these are the makers and part numbers:
for the abs motor relay
Nippon ABS LTD
112 000 10050
Japan 50532
Matsu****a
ACB32201 C01
CB1aF-12V
this one is good for Sebring and Avenger 95-96, and Talon 96
it is a 40A relay
the second one is the ABS valve relay
Nippon ABS LTD
112 000 20020
Japan 50210
Matsu****a
ACB12201 A02
CB1F-12V
this one is also a 40A relay
They can be found at Amazon.com in the Panasonic brand and also Beck/Arnley.
I hope this information is useful for other members of the forum.
