1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
transmission swap issue
Old May 2, 2014 | 10:35 AM
ericcarr2000's Avatar
ericcarr2000
Default transmission swap issue
Hi Guys, I am fairly new to this forum and need some help on a transmission swap problem I'm having and hoping someone on here can help me out. I recently had to replace my transmission in my 98 Avenger. Well I went to the bone yard and picked up a good used one that had only 56,000 miles on it for $300.00. I got it all bolted up and in there. I am having one electrical connector issue I'm having. I'm not quite sure what the connector itself is called so trying to find a replacement pigtail so I can splice into the wire harness is kind of hard at this point. The connector itself is at the drivers side, on top of the pan and has I think 9 pins in it. The problem I'm having is the pin spacing inside the connectors is slightly different. The replacement trans pin spacing is a tad bit closer than the harness itself.
Any help here on this would be greatly appreciated. Oh yeah, the replacement trans I was told did come out of a 98 Avenger, but at this point I'm not quite sure of that. For some reason I cant seem to figure out on how to post pictures.
