1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
2.5 wont start
Old Jun 25, 2014 | 11:24 PM
ericcarr2000's Avatar
ericcarr2000
Unhappy 2.5 wont start
Ok guys, as previously mentioned in past posts, I recently had to replace the transmission in my 98 Avenger with the 2.5 motor in her. Heres what I know to date. I replaced the trans, the motor ran good when trans went out, replaced the trans, trans shop replaced the PRNDL switch in the trans, motor gets spark and gas, good compression (180).....Engine wont start, just seems to turn over. Engine wont turn over other than in Park or Neutral so im assuming the switch is working correctly. I pulled the plugs a few hours ago and noticed that the plugs are saturated with gas but I do know the plugs are getting spark. I installed an inline spark tester and everything seems to be fine.
Any suggestions on this one?
Old Jun 29, 2014 | 02:39 AM
simmonsfr's Avatar
simmonsfr
Did you reinstall the correct flywheel? The v6 engines have a special flywheel that has a ring that signals the crankshaft position sensor.
