1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96 Avenger exhaust
Old Oct 4, 2014 | 05:47 PM
stfoer's Avatar
stfoer
Default 96 Avenger exhaust
I am looking at a stailess exhaust system, will the one made for these cars fit the Avenger?
95-99 Mitsubishi Eclipse RS/ GS Non Turbo
95-98 Eagle Talon Base/ ESi Non Turbo
(Fits Models with 2.0L/ 2.4L 420A/ 4G64 l4 NA Engine ONLY)
Old Oct 9, 2014 | 03:08 AM
stfoer's Avatar
stfoer
No one out there who knows?
Old Oct 9, 2014 | 07:11 AM
smokesxt's Avatar
smokesxt
Pacesetter used to make a system for the avenger. Look up that, then cross it with the Eclipse system, see if they will swap.
I want to say yes because they're the same chassis, but I can't say definatively.
Old Oct 20, 2014 | 08:04 AM
bad venge's Avatar
bad venge
Section Moderator
Those are about 8" short you can splice in to fit in front of the loop over the rear axle
Old Oct 29, 2014 | 04:49 PM
stfoer's Avatar
stfoer
OK, I got one set and will see how it works out.
Thank you
