1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Bad rear inside tire wear
Old Oct 9, 2015 | 11:16 AM
JLA74's Avatar
JLA74
Default Bad rear inside tire wear
I have been searching and found some information regarding how to fix the bad alignment caused by the bushing being worn on the rear suspension. I have had it aligned and this is this issue I have to repair. I'm just trying to figure out exactly which bushings to replace. Is it the ones on the mounts for the upper control arm?
Old Oct 10, 2015 | 10:12 PM
bad venge's Avatar
bad venge
Section Moderator
The alignment shop should have been able to tell you what was worn causing them to not be able to align it
Are you lowered ? how far off are the specs ?
Old Oct 11, 2015 | 11:38 AM
JLA74's Avatar
JLA74
Stock suspension. Small town garage doing the alignment so no additional info from them. Just trying to find out where to start. There doesn't appear to be adjustment options on the rear.
