1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Water pump replacement
Old May 8, 2018 | 06:39 AM
Partsman41953's Avatar
Partsman41953
Default Water pump replacement
Hi all,
I have a 1997 Avenger ES 2.5 with 150,000 miles on it. It sounds like the bearings are starting to go out in the water pump. I sprayed PB Blaster on it and the noise went away temporarily but now is back. I would like to know how difficult it is to replace the water pump. I saw the instructions which Bad Venge posted online and it looks very involved and was just wondering if a layman could do it or if it needs to be done by a mechanic in a shop.
Thanks
Old May 8, 2018 | 01:49 PM
Partsman41953
I also need to add that when I rev up the engine slightly and then take my foot off the accelerator the engine makes a sound the best I can describe it as sounding like a whale call and then after the engine is back at idle it stops. I tried spraying the water pump and alternator bearings with WD-40 but the noise did not go away. Anyone have any ideas what this could be?
Old Nov 4, 2018 | 01:40 AM
bad venge's Avatar
bad venge
Section Moderator
With 150K was the timing belt done ? it could be the tensioner
