1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Piston Compression PSI
Old Nov 27, 2019 | 12:41 PM
William Calero's Avatar
William Calero
Default Piston Compression PSI
hello,
on a ‘95, what should each piston compression should be?
Also, can someone please give me more guidance on how to read the blinking codes after turning the ignition switch on and off 3 times?
thanks you in advance
Old Nov 27, 2019 | 06:21 PM
Moparite's Avatar
Moparite
What psi do you have?
http://www.allpar.com/fix/80s-codes.html
Old Nov 28, 2019 | 01:09 AM
William Calero
piston 1= 150; 2=134; 3=140; 4=152.
thanks for the link. The flashes order are as follow.... 12, 21, 43, 43, 21, 13, 55. ( 55 supposed to be end of diagnostics according to link) .
thank you
Originally Posted by Moparite
