1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Accessory Lighting Power Source Required.
Old Mar 6, 2006 | 03:23 PM
harleyalij's Avatar
harleyalij
Default Accessory Lighting Power Source Required.
Hi there, just visited this forum today and caught up. Great place to be! I have a 95 Avenger, 2.0 and am a bit of a lighting fanatic. I would like to know if there are any available power sources in the car that can be used to put small neon tubes or wires on the inside. I do not want to go behind the deck. I did end up finding a source by the gear shift(underneath the cover) but am looking for some new ones. The lights i'll be connecting will be around the back seats.
Thanks
Old Mar 9, 2006 | 03:32 AM
daytonairoc's Avatar
daytonairoc
Default RE: Accessory Lighting Power Source Required.
if you are just looking for a hot wire when the ignition is on...... try tapping into the cig. lighter and run a wire to a distribution block. all will be gravy
