1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Crurse control
Old May 5, 2006 | 05:35 PM
95_Avenger's Avatar
95_Avenger
Default Crurse control
i cuise control works like half the time and when it does work and i hit a bump it shuts off i wanderin what it could be any body have any ideas.
Old May 5, 2006 | 09:25 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Crurse control
I'm betting on the cruise control components in the engine bay. Mine would do that at night.....when it was harder to see potholes. Mine also started to get "weaker", it would take it longer to realize that the speed had dropped 15mph slower than what was set. I think mine was the diaphram though.
Anyway, check you vacuum line(s) that go to the components and make sure that they aren't hard, they should be fairly soft and it should feel rubbery and not like plastic and check for tears in them too.
I would also suggest getting a Haynes/Chiltons manual if you don't already have one.
