1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Askin Help Again
Old May 21, 2006 | 07:16 PM
theflyingcow's Avatar
theflyingcow
Default Askin Help Again
My car wont run right. It keeps dying, and i dont keep it going with the gas peddal, then it will die. i changed my fuel filter, and it still does the same. i was wondering if anyone may know what the problem is. could it be the fuel pump, or the injectors??? or maybe an O2 sensor? Any help would be great....thanks
Old May 22, 2006 | 06:27 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Askin Help Again
The easiest thing to do and what I would do first is change your oil and PCV valve then if that doesn't help, clean the throttle area with some throttle body cleaner and then the chambers by using seafoam or mccc. Since you changed the fuel filter, I wouldn't put any down the tank, just down the intake.
