1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1997 avenger es CEL code
Old May 27, 2006 | 06:08 AM
jakbob's Avatar
jakbob
Default 1997 avenger es CEL code
i just bought a 1997 avenger es...and the check engine light is on...now i pulled the code and its PO134... wondering if you guys could help out the new guy on this forum..
Old May 27, 2006 | 06:19 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: 1997 avenger es CEL code
- P0134 (right rear)upstream o2 stays at center.
It's time for, the hardest to get, o2 sensor to be replaced..it's bad
It's the o2 closest to the intake manifold. You can try and remove it without lifting the plenum, but chances are you will have to remove it. not to worry though, because it's gasket is metal and that means it's reusable.
Another way to pull codes is to turn the ignition key on three times (never starting the car though) and on the third time leave it on the "ON" position. Next watch your Check Engine Light because it will blink 1-9 times once, then 1-9 time again...that's your first double digit set and it will repeat it if you have more codes. At the end you will get 5 - 5 or 55 that means it's done.
Not to get on you or anything but a Hayne's or Chilton's manual is really recommended before you do anything to your car.
...and welcome to the Dodge Forum boards
Introduce yourself in the "New Member's" forum
Oh, and don't forget to vote for me in this month's Ride Of The Month forum..no not really, but check it out the rides that are presented in there...good stuff.
Old May 27, 2006 | 06:32 AM
jakbob's Avatar
jakbob
thanks for the help and the welcome... o and this is my second avenger...so i am in somewhat familiar territory...o also, where do you get the code explanations...that would really help out in the future..
Old May 27, 2006 | 06:34 AM
silvercoupe97
Uber Moderator
Roger that bud
