1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Hood options
Old May 31, 2006 | 10:02 AM
stock92csm's Avatar
stock92csm
Default Hood options
Ok well i've read that hood and doors from a 95-99 eclipse will work on our cars, and we can do front end conversions for front bumpers and such well i have the option for so that being for a 95-99 eclipse will work with stock mounts and all correct?? wanna be sure before i buy it
Old May 31, 2006 | 10:06 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Hood options
It will work......however....
You will need to get the fenders, fascia, headlights, and that radiator mount, otherwise you will have unmatching lines.
The lights are longer and have more of a curve to them and you will need the fenders to fit the headlights, the Eclipse fascia to fit the headlights and the hood, and then the radiator support bracket to fit the fascia on.
You're basically converting the entire front end into an Eclipse.
Old May 31, 2006 | 10:12 AM
stock92csm's Avatar
stock92csm
i've been thinkin about doing this so i think i will i just need something to put on my wrecked venger while it's being repaired a radiator from an eclipse nt is the same as an avengers correct?
Old May 31, 2006 | 10:14 AM
silvercoupe97
Uber Moderator
Yeah, you might as well grab everything in the front of the Eclipse (minus the motor) and put that onto your Venge.
Old May 31, 2006 | 10:15 AM
silvercoupe97
Uber Moderator
I guess the technical answer to your original question should be a "Yes", yes, it will bolt on........BUT....NO, it will not fit correctly on it's own.
Old May 31, 2006 | 10:47 AM
element000101's Avatar
element000101
will the hood fit our avengers...i was thinking bout doing the same thing
