1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
avenger no start
Old Jun 1, 2006 | 04:52 PM
jakbob's Avatar
jakbob
Default avenger no start
so i was leaving a restaurant and get into my avenger, it wouldnt start. the engine turned over like it always does, but didnt start. so i pop the hood and try again, it started. i thought it was just something random. so i go home. well later that night, it did it again. and now, it just wont start whatsoever. i can hear the fuel pump prime when im about to start it, and im pretty sure i have spark...im thinking maybe its something in the fuel line...i need ideas...help! (especially silvercoupe...)
Old Jun 1, 2006 | 06:16 PM
jakbob's Avatar
jakbob
Default RE: avenger no start
pulled a code using the keydance...came up 1 flash, pause, 2 flash, pause, 1 flash, pause, 1 flash, pause, 5 flash. i am assuming that means 1211 and the 5 is the code saying "thats it". so i checked and it said 1211 Mass Air Flow Intermittent High. what does that mean? do i need to replace it, is the connector loose, or what?
Old Jun 2, 2006 | 03:02 PM
jakbob's Avatar
jakbob
nevermind. its actually code 12 and 11...and 11 could be 3 things....
Old Jun 2, 2006 | 06:34 PM
jakbob's Avatar
jakbob
ok so i pulled the crank pos sensor and the distributor...looking to get another, but i need to know if the 2.5 has the small rotor cam or the large rotor cam...and whats the difference...and also, how can i test the Cam postion sensor and the crank position sensor cause i dont feel like paying 250 bucks for a part i dont need...
Old Jun 2, 2006 | 10:47 PM
jakbob's Avatar
jakbob
fixed...it was the crankshaft position sensor
Old Jun 3, 2006 | 08:56 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Good job Jakbob and thanks for the follow up. Sorry I wasn't here to help
You're reading the codes right too...almost looks like you got it in the third post though. The "end code" numbers are 5-5 or 55...no blinking!!! kidding, lol.
Old Jun 4, 2006 | 12:57 AM
jakbob's Avatar
jakbob
yeah i thought it would be a 4 digit code like with a scanner...but yeah, it runs fine now...
