1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
changing antifreeze
Old Jul 13, 2006 | 01:50 AM
redaveng99es's Avatar
redaveng99es
Default changing antifreeze
Well I am going to change my antifreeze and upper and lower radiator hoses. Is there anything I should know before I change it. I am waiting for the hoses to come in and cause Napa didn't have them in stock. I am going to run some water through and drive it some just to clean it out some. Any other helpful hints would be awesome.
Old Jul 13, 2006 | 02:17 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: changing antifreeze
No need to drive it around with water in the system. Just remove the hoses and thermostat, put the hose where the thermostat was and turn on the water and let it flush, do the same for the radiator after you've removed the upper and lower hoses.
