need help abs
the fuse off the fuse block for the anti lock brake was pulled out . and the noise from underneath the hood stoped what do i need to replace ?
and also the anti lock brake light is on .
thanks in advane
mz sexia !
and also forgot to mention its a 1995
http://www.mzsexia.com
thanks in advane
mz sexia !
well it could be a couple things nething from sensors and relays to the abs pump.....when the fuse was in did the light come on after you started driving cuz that would be a sensor ( think if the computer didnt read the sensor the light would come on after +5 mph driving).....but from the sound your hearing i think it might be a bad abs pump......best thing to do is change the relays and fuse n if the noise goes away and the light goes off good 2 go otherwise when dealing with brakes and your anti lock system take it to a shop n have them look at it
