1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
whistling noise from firewall area
Old Sep 7, 2006 | 03:11 AM
cbccadet2002's Avatar
cbccadet2002
Default whistling noise from firewall area
i have a sound like a whistle coming from the firewall every once in a while during take-off. i can only hear it in first gear, then the fart pipe is to loud. could this be a vacuum leak? it doesn't always happen so that takes out the windshield, right? thanks alot
Old Sep 7, 2006 | 03:37 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: whistling noise from firewall area
Try revving the motor while in park and see if you can simulate the noise. There's a pulley on the throttle body that is connected to the gas pedal so that you don't have to sit in the car to rev it up. Rotate that pulley and tell us what you find out.
