belt noise plse help!!
Hi I've had my 97 Dodge Avenger for about year and haven't really had any problems with it until now. When I turn the car on it starts to make a high pitch sqeeking noise. I think its the fan belt being too tight does anyone know how to loosen the belt. I'd really appriciate help.
thank you
thank you
is it a new belt?...... try to find out if its the friction between the belt n the pulley thats causing the squeak or if its just the pulley.....try belt dressing or a new belt.... could be a bearing in the pulley gone bad....investigate n feed the info back 2 us
It's a new belt but it has been on my car for a month with no trouble. I've also tried to put belt dressing on it the noise didn't stop. How would i stop the pully from making noise if that is the problem?
