1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Parking Break Light Malfunction
Old Oct 1, 2006 | 10:13 PM
odel0022's Avatar
odel0022
Default Parking Break Light Malfunction
Just recently whenever I apply the brakes on my '95 Avenger ES, my parking brake light on my console turns on. When I stop pressing the brake, it goes away. Sometimes it does it sometimes it won't...any suggestions?
Old Oct 1, 2006 | 10:24 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Parking Break Light Malfunction
Welcome to DF.
Have you checked your brake fluid resevoir lately?
Old Oct 1, 2006 | 11:28 PM
PappiDread6's Avatar
PappiDread6
Was your car preowned? If so I know people to mix wires around to stop 1 thing from happening and force another to come on. "Jimmy rigged" I would check fluid first since its easiest then check your fuses.
Old Oct 2, 2006 | 03:19 AM
odel0022's Avatar
odel0022
i will check the brake fluid tomorrow. It is a pre-owned car but I have had the car for about 2 years now and this just started happening recently. I will post an update when check my fluids. Thanks for your help!
Old Oct 2, 2006 | 09:02 AM
silvercoupe97
Uber Moderator
Do you use your e-brake? If so, you may also want to check your e-brake pads or it may just need adjusting.
Old Oct 2, 2006 | 05:40 PM
cky00's Avatar
cky00
my car started donig that about 1 mnth ago and i never thougt anything of it and it went away .... may not be the same as your car but tahts wut i experieieieeneced
