1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Brake Help Please!!!
Old Nov 1, 2006 | 02:07 AM
xenocamry's Avatar
xenocamry
Default Brake Help Please!!!
I bought a 2000 Avenger about a week ago. It has 35,000 mles on it. It has such low miles becouse it sat at a dealer for almost 4 years. I purchased it thinkng it only needed brake rotors and new tires.
The problem is when I brake at slow speeds, under 20mph, i get a pulsating/thumping through the pedal. It also seems to increase in frequency when I brake while making a relatively tight turn (think jughandle). I put new rotors and pads on. Calipers were fine. New tires (they were balanced) and the prolem persists. I bleed the brakes, and still no change. I have no idea what could be wrong with it. Im about to take it to a dealer (but I dont want to becoue it wil cost a fortune.
Other then the brake problem the car is extreamly clean and unblwmished, Its not likely that this is a result of an accedent.
Any ideas what it could be?
Possibly the result of the ball joint recall?
Thanks
