best plugs to use
Hey guys was just wondering what are the best spark plugs to use in the 2.5?? an wondering where is a good place to get susp. parts at and at all good deal?? everything from the rubber sway bar pieces to the shocks and so forth.. thanx all
I've used only stock replacements so I can't comment on the other brands, but I have seen that others recommend using stock replacements and making sure that they are the Platinums(?). As for the parts. I use AutoPartWarehouse they have pretty decent pricing on OEM parts and they usually arrive fairly quick (even for Hawaii standards).
i have the boch plats but you aint goin to notice any differense in the more exspensive ones. i only got them because the manger at auto zone gave me the wrong ones at first so gave me them so show his aplogies.
That's the ones. You only have to change them once every 75k miles I believe. So it's not like you're paying that much when you consider the time between changes. You're right, you won't see a difference with higher end plugs. The distributor will only send X amount of power for spark so going with higher dollar will just be a waste IMHO.
yea i used the irduims by denco in my 87 bmw 535i and i noticed a lil bit more power but not a amount really just real crisp throtle and so forth.. i have the bosch plats now and i will be taking them out because of my pcm problem back a few months... i beleave the engine running as bad as it was for that long i think they need it agian so ima buy plats and a new intake gasket and change away lol thanx all
joe 95 es running strong
just hit 160,000
just hit 160,000
