1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Viper Body Kit
Old Nov 16, 2006 | 03:42 PM
stewdog9's Avatar
stewdog9
Default Viper Body Kit
hey, i was fitting my viper front bumper on my 96 avenger and when its on you cant get to the hood latch, do i have to rig it so i dont have to use the secondary latch?
Old Nov 17, 2006 | 02:18 AM
blackvenge34's Avatar
blackvenge34
Default RE: Viper Body Kit
do u have urethane or fiberglass cuz mine is urethane and it fit perfectly and i didnt have to rig anything for the latch?
Old Nov 19, 2006 | 02:26 AM
stewdog9's Avatar
stewdog9
mines fiberglass
Old Nov 22, 2006 | 10:50 PM
ACE's Avatar
ACE
Are you saying the fiberglass of the bumper is covering the latch area? Just cut a notch out of it? Fiberglass is easy to work with, so you can just use an angle grinder or sharp tool to cut a notch to gain access.
Or are you saying something else?
Old Nov 24, 2006 | 09:36 PM
stewdog9's Avatar
stewdog9
ya, my fiberglass bumper is blocking me from getting to the latch, ill just disconnect the second latch i geuss.
Old Nov 25, 2006 | 02:57 AM
PappiDread6's Avatar
PappiDread6
Which is better? I'm guessing the Carbon Fiber is stronger and the urethane is lighter
Old Nov 25, 2006 | 08:53 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Carbon fiber will crack like fiberglass, urethane is the same material as the stock fascia. Urethane will bend and flex and will only rip if you put a lot of pressure on it. Urethane is more expensive than fiberglass, but it will outlast it if you're lowered or going to be. Carbon fiber, IMO, is a waste of money because that's a lot of money to spend on something that will just crack like the cheaper fiberglass. CF, IMO, is for show cars and not DD cars, again, IMO.
Since you have an aftermarket hood, I assume you have hood pins? If you disconnect the secondary latch, you will definitely need hood pins. Have you ever seen what a hood will do at highway speeds to a windshield? Hood pins are cheap, a new hood and windshield is not
Old Jun 5, 2008 | 10:30 AM
SPIKENOX07's Avatar
SPIKENOX07
I'm planning to get the viper body kit for my 95 avenger. When I talked to the body shop, he said that side skirts can be attatched in many different ways. (ie: bolts,plastic latch, glue)I would like to know how the viper side skirts are put on. Once I know this I'll be able to get a more accurate estimate.
Old Jun 5, 2008 | 12:08 PM
bad venge's Avatar
bad venge
Section Moderator
Most use screws into the front fender and the front of the rear fender and a few screws in the door opening bottom
