1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96 avenger wont start
Old Nov 28, 2006 | 11:53 PM
jimbo_01's Avatar
jimbo_01
Default 96 avenger wont start
i've been having problems with my 96 avenger with the 2.5 v6 for months now. the problem is that it will start up and run fine and then all of a sudden it just wont start. then a while later it will start again. so far i have had a distrubitor put on along with a new fuel pump and fuel filter. the car is currently sitting and wont start. it has spark at the spark plugs and if you spray starting fluid(ether) into the throttle body it will start up and run on that. so is their anything besides the fuel pump that could just be cutting out the fuel?
thanks for any help since no shop around here can find the problem.
Old Nov 28, 2006 | 11:59 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: 96 avenger wont start
Have someone turn the ignition to the ON position, with the hood open, put a finger on each of the first two relays and feel for the "click". The ASD controls the ECU power and the second one is the fuel relay. Let me know where you stand after that.
Old Nov 29, 2006 | 12:12 AM
jimbo_01's Avatar
jimbo_01
i'll do that tomorrow and let you know. my avenger has three relays so in order from left to right it should be the fuel pump relay, asd, eatx. correct? i know that some shop replaced the middle one(asd) while i've been having problems because the new relay doesn't have the mounting braket on it. where's the best place to get new ones at?
Old Nov 29, 2006 | 12:14 AM
silvercoupe97
Uber Moderator
Yup, here's some more info on those relays too.
https://dodgeforum.com/m_554757/tm.htm
Old Nov 29, 2006 | 01:40 PM
jimbo_01's Avatar
jimbo_01
well all of the relays are clicking.
Old Dec 5, 2006 | 10:26 PM
tvfoxdude's Avatar
tvfoxdude
I had the same problem with my '95. It ended up being the Cam sensor, wich is either integrated or part of the Distributor, I didnt tear it apart to see. A new distributor comes with one, and a hefty price tag ($1,250). A used or reman. one usually is around ($300.00)
Advance Auto does sell the Crank and Cam sensors for around $100.00 each, but I dont know how hard they are to change. Hope this helps
Jim
